I've noticed that cutting speeds up when the path is a straight line. This seems to be causing issues with many of my cuts. Is this a setting that can be adjusted?
Thanks!!
Speed of Straight Cuts
Re: Speed of Straight Cuts
Your machine is probably not capable of cutting the non straight areas at the programmed speed so it slows down in those areas. You can use cut rules to force a slow down in certain areas, but there isn't a way to slow down a straight path unless you just slow the feedrate in the tool.
This makes perfect sense, but is not something I had thought of. Thank you!
