hole too small ..
Redge
hole too small ..
Post by Redge »
Hello, im cutting 1inch thick plate with oxy-acetyle(flame cutting). I choose .125 kerf, my outside is right but my hole is too small. I got 1.5inch hole and my draw is 1.75inch. What should i do to fix it ?
djreiswig
Re: hole too small ..
Post by djreiswig »
Do you have the offset in your operation set correctly? Outside offset for an object and inside offset for a hole. Also, you may have to slow down your feedrate on the hole to let the flame catch up.
Redge
Post by Redge »
Thank you very much !! im gonna check these for the next job ..
