V5.1.31
Changed: Much improved debugger for Lua scripts and posts
V4.1.35
Fixed: Debugger losing breakpoints when you save a post
Which would indicate there is a debugger. How do I go about opening the debugger. Would like to debug a post.
I'm using 6.1.53 SheetCam TNG Development build with eval license.
I have managed to open a code editor but it is for Gcode, not the lua posts.
Thanks.
Greg
I found it, from the main menu select Options | Machine, then select the post you want to use/debug, then click the Edit Post button. That brings up the post in an editor/debugger.
