Inside dimension is off
Posted: Mon Aug 12, 2019 11:02 am
I've been running my table for a few years now with this problem but haven't really cared to fix it til now. When cutting a part that has outside and inside profiles, the outside comes out with perfect dimensions. The inside however tends to have more of an offset than it should, causing all my inside cuts to be smaller than originally drawn. If I adjust the kerf to match it would affect my outside dimension. Is there anyway to adjust the inside offset without having to put them on another layer? I'd like to be able to apply an inside kerf and an outside kerf width to be able to fix this. Or is it possible to fix this in the post?
