Just wondering if is it possible to add more options in the operation menu? Now that I have a plate marker it would be great to not have to be changing settings I the Jet Cutting tab all the time.
Rod
Operation menu
Re: Operation menu
This isn't documented but post.DefineCustomToolParam also works for operations. For instance this code:
would create an option called 'Extra parameter' which would appear in the post as the variable extraParam. It would default to 100 with a minimum of 0 and a maximum of 1000.
post.DefineCustomToolParam("JetOperation", "Extra parameter", "extraParam", sc.unitLINEAR, 100, 0, 1000)
