Router bit change during a cut job
kldesigns
Post by kldesigns »
I am trying to figure out how to do a bit change from a larger bit to a smaller bit in the middle of a router cut job. I want to use a larger bit to router out the larger areas but I need a smaller bit to fit into the smaller more detailed places on the image. How do I have it pause during the cut and allow me to change out the bits? I have found the Tool Change tab under the Job Options drop down but I don't know what to do once I am in there. I am not sure where I find the answer to the tool position and the code that is ran before and after the tool change. I am very new to this so any and all advice, tips, and/or tutorials would be greatly appreciated! Thank you in advance for taking the time to help me!
Thank you!
Keli
