Rule set hesitation
Richcreek
Rule set hesitation
Post by Richcreek »
Diy plasma hesitates/pauses on the start of a rule. I'm running a masso controller with their modified post processor for a THC . The machine works great with no rules and THC off
Thanks for the support
robertspark
Re: Rule set hesitation
Post by robertspark »
That will be a common thing.
It will be common to very many motion controllers unless they are able to issue commands (m / miscellaneous codes) in sync with motion.
It's not a sheet am issue, you need to study your motion controller m and g codes and try to establish what functions run in sync with motion (is do not slow down and or speed up when being implemented)
.... Product plug... You don't get this with UC motion controllers running uccnc.... Not that it helps you out but you probably want to ask whoever develops the motion controller to expand their sync m codes available for plasma and laser where overburn can occur at the slowdown points
