Scananything+mach4
Cattle
Scananything+mach4
Post by Cattle »
I have downloaded scananything from sheetcam (recommended from Arclight) and when I was following directions for setup I noticed that it requires Mach3 plugin. I am running mach4 and when I try to find the plugin in sheetcam it indicates not found. Is there a way around this or am I am not able to use the scananything program with Mach4
Thank you
