No speed defined for torch travel
MarkB
Post by MarkB »
Newbie here:
My table is working fine except the really SLOW motion of the torch, around 3" per minute. This code should say 140" per minute per the way i set up the Jet cutting operation for 140" per minute. N0050 says F1 which i have read is a place holder.
is there a decent list out there what .... say F47.2241 mean, a decoder ring. (old guy reference there)
HELP
I tried to search for F1, speed etc but the phrases were too common for the search engine.
N0010 (Filename: WheelSprocketAdapterStrippedC3.tap)
N0020 (Post processor: CNC Router Parts OHMIC.scpost)
N0030 (Date: 04/01/2019)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: WheelSprocketAdapterStripped)
N0080 (Operation: Outside Offset, 0, T1: Plasma, 0.063 in kerf)
N0090 G00 X2.4650 Y0.2062
N0100 G31 Z -100 F47.2441
N0110 G92 Z0.0
N0120 G00 Z0.1500
N0130 M03
N0140 G04 P0.5
N0150 G01 Z0.0591 F3.937
N0160 G02 I0.0000 J0.0935 F140.0
N0170 M05
N0180 G00 Z1.0000
N0190 X3.2111 Y0.4897
N0200 G31 Z -100 F47.2441
N0210 G92 Z0.0
N0220 G00 Z0.1500
N0230 M03
N0240 G04 P0.5
N0250 G01 Z0.0591 F3.937
N0260 X3.1280 Y0.4341 F140.0
N0270 G02 I0.0000 J0.5285
N0280 M05
N0290 G00 Z1.0000
N0300 Y-0.5372
N0310 G31 Z -100 F47.2441
N0320 G92 Z0.0
N0330 G00 Z0.1500
N0340 M03
N0350 G04 P0.5
N0360 G01 Z0.0591 F3.937
N0370 G02 I0.0000 J0.1247 F140.0
N0380 M05
N0390 G00 Z1.0000
N0400 X2.2224 Y1.1117
N0410 G31 Z -100 F47.2441
N0420 G92 Z0.0
N0430 G00 Z0.1500
N0440 M03
N0450 G04 P0.5
N0460 G01 Z0.0591 F3.937
N0470 G02 I0.0000 J0.0935 F140.0
N0480 M05
N0490 G00 Z1.0000
N0500 X1.7530 Y0.8378
N0510 G31 Z -100 F47.2441
N0520 G92 Z0.0
N0530 G00 Z0.1500
N0540 M03
N0550 G04 P0.5
N0560 G01 Z0.0591 F3.937
N0570 G02 I0.0000 J0.1247 F140.0
N0580 M05
N0590 G00 Z1.0000
N0600 X2.8853 Y1.7747
N0610 G31 Z -100 F47.2441
N0620 G92 Z0.0
N0630 G00 Z0.1500
N0640 M03
N0650 G04 P0.5
N0660 G01 Z0.0591 F3.937
N0670 G02 I0.0000 J0.0935 F140.0
N0680 M05
N0690 G00 Z1.0000
N0700 X3.1280 Y2.2128
N0710 G31 Z -100 F47.2441
N0720 G92 Z0.0
N0730 G00 Z0.1500
N0740 M03
N0750 G04 P0.5
N0760 G01 Z0.0591 F3.937
N0770 G02 I0.0000 J0.1247 F140.0
N0780 M05
N0790 G00 Z1.0000
N0800 X3.7909 Y1.5320
N0810 G31 Z -100 F47.2441
N0820 G92 Z0.0
N0830 G00 Z0.1500
N0840 M03
N0850 G04 P0.5
N0860 G01 Z0.0591 F3.937
N0870 G02 I0.0000 J0.0935 F140.0
N0880 M05
N0890 G00 Z1.0000
N0900 X4.5030 Y0.8378
N0910 G31 Z -100 F47.2441
N0920 G92 Z0.0
N0930 G00 Z0.1500
N0940 M03
N0950 G04 P0.5
N0960 G01 Z0.0591 F3.937
N0970 G02 I0.0000 J0.1247 F140.0
N0980 M05
N0990 G00 Z1.0000
N1000 X3.0448 Y-0.8745
N1010 G31 Z -100 F47.2441
N1020 G92 Z0.0
N1030 G00 Z0.1500
N1040 M03
N1050 G04 P0.5
N1060 G01 Z0.0591 F3.937
N1070 X3.1280 Y-0.8189 F140.0
N1080 G03 I0.0000 J1.7815
N1090 M05
N1100 G00 Z1.0000
N1110 X0.0000 Y0.0000
N1120 M05 M30
WheelSprocketAdapterStripped.job
Here you go.
(10.21 KiB) Downloaded 50 times
Re: No speed defined for torch travel
Could you post a copy of your job file (File->save job) with everything set up ready to cut. I'll take a look and see what is going on.
If you open your cut operation (double click on where it says 'Outside offset,0,T1: Plasma, 0.063 in kerf'). You will see that the feed rate is set to 3.937IPM.
