Deunion multiple objects/images
Ghscncclass
Post by Ghscncclass »
Is there a way to un union multiple objects/images? I need to fix one part of my sign, but the entire sign is unioned together. Is there a way to de-unuion it so that i can fix the one image that was inserted?
WyoGreen
Re: Deunion multiple objects/images
Post by WyoGreen »
I suspect you will have to take the design back to whatever program you used to design it and un-group it there.
If you right-click on the part name and select 'break up manually nested drawing' it will break your drawing into individual parts. Note it is best to set up your cut operations first, otherwise you will have to set up operations for each part.
