TABLE MATERIAL ORIENTATION ISSUE
Using Sheetcam along with Mach 3 on a CNC Plasma Table.. The issue I have is material placement on the table. I draw on Z axis on the lower left XY. My material and table are both setup in SheetCam for the same lower left AXIS. My Computer is located at what would be the top right corner, I am trying to setup the material and machine to operate at the top right so I am looking at everything correctly from the computer screens. Is this possible? I tried changing everything to the top right but the CNC machine then wants to cut/run off the table boundaries....
Re: TABLE MATERIAL ORIENTATION ISSUE
In SheetCam go to Options->job options and set the origin to the top right.
