Making use of usable material after plasma cutting
Searchman
Post by Searchman » Thu Oct 11, 2018 11:53 pm
I have material between cutouts that are usable for smaller cutouts.
Is there a way to setup Sheetcam or Mach to utilize the usable areas and have the torch x-y go to a pre determined spot and start the cut?
SeanP
Re: Making use of usable material after plasma cutting
Post by SeanP » Fri Oct 12, 2018 9:24 am
Are you entering sheet size into 'job options' and laying out parts on the sheet? that way you can save the sheet as a 'job file' and then zero up on x & y layout new parts in the gaps,disable original parts and cut away.
I label up sheets of various sizes with job file number ie: 6OC12 (6mm October 12th)
motoguy
Post by motoguy » Wed Oct 31, 2018 3:17 am
Yup, what SeanP said. Save job file, which should match sheet remnant. Open job file at a later date, add parts to fill cuttable area, re-save job file, index old remnant sheet, and cut again. Repeat until you've used all the old sheet.
