new to sheetcam and I finally found a pp that works but when I start a file the m03 starts right away then moves to first cut the rest of the file works like it supposed to what and how can I change it?
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("EaziCNC plasma post processor\n")
ctrl:AppendText("\n")
ctrl:AppendText("Generic plasma post for machines without THC\n")
ctrl:AppendText("M03/M05 turn the torch on/off\n")
ctrl:AppendText("Incremental IJ\n")
ctrl:AppendText("G04Sxxx pauses\n")
ctrl:AppendText("Tool numbers 100 and upwards are plate marker\n")
ctrl:AppendText("Plate marker uses M08/M09\n")
ctrl:AppendText("Set the markerX,markerY and markerZ values for the marker offset\n")
ctrl:AppendText("slowradius - slow down below this radius\n")
ctrl:AppendText("slowspeed - minimum percentage to slow down\n")
-- created 31/3/08
-- Based on Mach2 plasma.post
function OnInit()
xOff = 0
yOff = 0
zOff = 0
if(scale == metric) then
else
post.Text (" G53 G90 G40\n F1\n S500\n")
markerX = 1000 -- Plate marker X offset in millimetres
markerY = 2000 -- Plate marker Y offset in millimetres
markerZ = 3000 -- Plate marker Z offset in millimetres
slowradius = 10 -- arcs smaller than this will be slowed down
slowspeed = 0.25 --minimum speed (0.25 = 25%)
function OnNewLine()
post.Text ("N")
lineNumber = lineNumber + 10
function OnFinish()
post.Text (" M05 M30\n")
function OnRapid()
post.ModalText (" G00")
post.ModalNumber (" X", (endX + xOff) * scale, "0.0000")
post.ModalNumber (" Y", (endY + yOff) * scale, "0.0000")
post.ModalNumber (" Z", (endZ + zOff) * scale, "0.0000")
post.Eol()
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, "0.###")
post.Eol()
function OnArc()
radius = math.hypot(endX - arcCentreX,endY-arcCentreY)
if (radius < slowradius) and (math.abs(arcAngle) > 0.5) then
feed = (radius / slowradius)
if(feed < slowspeed) then feed = slowspeed end
feed = feed * feedRate
else
feed = feedRate
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
post.Text (" I")
post.Text (" J")
post.ModalNumber (" F", feed * scale, "0.0###")
post.Eol()
function OnPenDown()
if(tool >100) then
post.Text (" M08\n")
else
if (preheat > 0.001) then
post.Text ("\n G04 S")
post.Number (preheat,"0.###")
post.Eol()
post.Text ("\n M03\n")
if (pierceDelay > 0.001) then
post.Text (" G04 S")
post.Number (pierceDelay,"0.###")
post.Eol()
function OnPenUp()
if(tool >100) then
post.Text (" M09\n")
else
post.Text (" M05\n")
if (endDelay > 0) then
post.Text (" G04 P")
post.Eol()
function OnNewOperation()
post.Text (" (Operation: ", operationName, ")\n")
function OnComment()
post.Text(" (",commentText,")\n")
function OnToolChange()
-- text (" M06 T")
-- number (tool, "0")
post.ModalNumber(" F",feedRate * scale,"0.#")
post.Text (" (", toolName, ")\n")
if(tool >100) then
xOff = markerX
yOff = markerY
zOff = markerZ
else
xOff = 0
yOff = 0
zOff = 0
function OnNewPart()
post.Text(" (Part: ",partName,")\n");
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
post processor
Re: post processor
What machine controller are you using?
Looking at that post I can't see any obvious reason whay it would turn the torch on before the first cut. Could you give me a copy of the g-code.
Re: post processor
les how and where do I set float switch in the code with back off?
Re: post processor
That post isn't set up to do a touch-off. If your machine is doing a touch-off before the pierce it must be a macro or setting in your controller.
