I have 2 error messages when I go to "Options", "Job Options" and then exit or save:
1 - Advanced cutting rule set "Holes":1 Unable to find code snippet
2 - Advanced cutting rule set "EOCAnti-Dive":1 Unable to find code snippet
I also have the problem of the material box only having a white outline - not a red filled box.
Any thoughts would really be appreciated.
Thanks, Dave
Error messages
Re: Error messages
You have some cutting rules set up that are configured to use code snippets but those snippets have not been defined. Are you using a rule set that was supplied to you? If so you probably need the tool set that came with it.I have 2 error messages when I go to "Options", "Job Options" and then exit or save:
Re: Error messages
Thanks for the reply, I appreciate your help. Dave
