Arc to radius problem
plasmaguy
Post by plasmaguy »
Hi, when in LinuxCNC, say my plasma failed to fire and I try to make the cut again using "Run from here", I am getting a message that the arc radius is different from the start point. Is there a way to fix my issue? Thank you.
djreiswig
Re: Arc to radius problem
Post by djreiswig »
In Mach you have to back the code up further. I turn off dthc and start from a ways back and then manually fire the torch and turn dtch on when I get to the right place to start cutting. Assuming it is similar in Linux.
