Which post processor?
I’ve looked through this forum for which post processor I should be using with Mach3 and Proma THC. I have decided that it should be Mach3 THC with scriber but this seems to be only for millimeters and it says to set the switch offset in millimeters. My table is set up in inches. Is there a way to set this post processor up in inches?
Re: Which post processor?
The post can be configured to output in inches or millimetres. You can choose the units in Options->machine->post processor->units.
Internally SheetCam and the post processors always work in millimetres so the settings need to be metric.
That you for your quick reply. That’s exactly what I needed. Working better than I would have hoped.
