Just recently upgraded pc. Running ComandCNC and sheetcam-TNG-dev 6.1.41on a plasma table
Need to change my feed rates on tools to show in/min instead of mm/min. Have done this in the past when we have replaced/repaired pc before but dont remember where I found it
I also keep getting an error on closing sheetcam, "failed to update user.configuration file"
10:36:43 AM: can't create file '/home/plasma/.SheetCamTNG-dev' (error 21: Is a directory)
10:36:43 AM: can't commit changes to file '/home/plasma/.SheetCamTNG-dev' (error 0: Success)
10:36:43 AM: Failed to update user configuration file.
The error started sometime back after trying to do an update that failed
John
changing feed rate to inches and error on closing
- log.txt
- (238 Bytes) Downloaded 79 times
Re: changing feed rate to inches and error on closing
Install the latest version. That will fix the problem.
