Failed Measuring Delay (15) error on scananything
I am trying to get scan anything set up to run and I get this error when I calibrate. Failed Measuring Delay (15) is what shows up. I get the blue circle and the green circle and they will line up, but has to restart because of this error. Any ideas? Thanks in advance.
Re: Failed Measuring Delay (15) error on scananything
Is this the Linux version or the Windows version?
Linux using with Command CNC.
It is failing to see the dot as it moves left<>right. Switch to mask mode and run the calibration again. Can you clearly see the dot moving as it calibrates? You may need to experiment with the brightness slider to get the clearest image.
Thanks, I guess I was not patient enough.
