Hello,
i am looking for a postprocessor for sheetcam that works with usbnc and a tangential knife.
Can annybody help me ?
Regards
HP
tangential knife postprocessor for usbcnc
Re: tangential knife postprocessor for usbcnc
Is this from Planet CNC or Eding CNC? There are two systems with siilar names.
Hi,
it is Eding CnC
it is Eding CnC
This one should do teh trick. It is supplied with the development version of SheetCam. To install this post, save the attachment to any convenient folder on your computer then run SheetCam and go to Options->machine->post processor. Click on the 'Import post' button. Using the box that appears, navigate to your post and open it. Now click on the 'Edit post' button. At the strat of a file are a number of options that yo uneed to set up to suit your machine.
- Mach3 Tangential V2.scpost
- (13.23 KiB) Downloaded 428 times
Hello Les,
thank you very much. I will check it within the next weeks.
Yesterday I have bought the drag knife plugin. The first cut will be done next days.
Regards
HP
Regards
HP
