Torch finding metal
Torch finding metal
Is there a way I can program for the torch to find the metal every time. My software is set for 500 MM (19.625 in.) Thanks
Re: Torch finding metal
It depends on your post processor but these instructions should work for most. Go to Options->machine->post processor and click on the 'Edit post' button. Near the start of the post should be a bunch of configuration options. One of them should be refDistance. If you set that to 0 it will reference on every cut.
If you can't find the settings let me know what post you are using.
Thanks Les, I'll try that and let you know
