I'd like to mill a slot from one end to the other, plunge at the far end and return and repeat to depth. As far as I can see the program now mills the slot, lifts the tool to the safe retract height and does a rapid back to the beginning of the slot and starts again.
Is there a way to achieve this action?
milling a slot with no no tool lift
Re: milling a slot with no no tool lift
In your cut operation go to the 'Cut path' tab and turn on 'Reverse open paths'. That should do the trick.
Excellent. Thanks.
Sage
Sage
