g-codes won't load to mach3
Plasron
Re: g-codes won't load to mach3
Post by Plasron »
Les Newell wrote: Sun Jan 14, 2018 7:26 pm I'll send you a PM with the details.
Thanks Les
Capemonroe
Post by Capemonroe »
I am having the same problem as Ivan. I can download art and import the dxf file into sheetcam. I can save the job BUT when I run the post processor it is not creating a valid tap file. When I try to open the G code in Mach 3 it only have a few lines of code. I have attached the job file and tap file. ANY help would be greatly appreciated. I should note that this just started and only on new downloads. It will open previously save tap files no problem. Also I do have a license with both sheetcam and mach 3. Thanks!
3Gnomes with Hearts.tap
(208 Bytes) Downloaded 50 times
3Gnomes with Hearts.job
(97.36 KiB) Downloaded 55 times
