I've modified my post processor to make line numbers increment by 1 instead of 10.
However, the line numbers start at 10 instead of 0.
I changed this:
function OnNewLine()
post.Text ("N")
lineNumber = lineNumber + 10
to this:
post.Text ("N")
which made the lines increment by 1, but no idea how to get them to start at zero.[/code]
Here's the start of the code:
N0010 (Filename: BOLT TAB.tap)
N0011 (Post processor: NeuronThcUccncPost (BEEFY).scpost)
N0012 (Date: 28/12/2017)
N0013 G90
N0014 F1
N0015 (Part: BOLT TAB)
How to make line numbers start at zero.
Add this as the first line of function OnInit()
lineNumber = 0
Re: How to make line numbers start at zero.
Thanks Les,
the reason I'm doing this is so the gcode line numbers match the way my cnc controller reads them.
Keith.
Keith.
