yes I'm still getting the compressed code so I'm thinking i may go the route of a new computer and pay for new software.mancavedweller wrote: ↑Fri Dec 29, 2017 2:13 pm OK, based on the information I have from you, all I can suggest is using the following post processor:
Mach3 plasma no Z
Your table appears to have two X axis motors, one Y axis motor, and you simple mount the torch on the Y axis plate, i.e. no up/down control.
I generated gcode in Sheetcam using that post processor and it seemed to give out the right type of code for your design of table.
code not showing
Re: code not showing
sheet cam license isLes Newell wrote: ↑Fri Dec 29, 2017 9:40 amXP is fine. It sounds like a license issue to me. Even if you have the wrong post processor you should see more code that you are getting.
Your Mach license looks very suspicious as well. Mach licenses usually have your name. What name is your SheetCam license made out to? You can find it in Help->about.
Sheetcam TNG
6.0.24
registered to : Angel Delgado
License id : U4FH****
That's a pirated license and it won't work any more.
Thanks for the help , my computer guy is building me a system as we speak and i will purchase new programs when I'm ready to run .
OK New computer is here purchased the sheet cam license and mach2/3 license of the website ? where do i get the mach 3 license from?
Mach licenses can take up to 24 hours to arrive because I have to order them from Mach Support.
Its all licensed now ,but when i run the code in mach my machine just kinda shunts left over till it stops > is this just settings i have to play with i will upload a video end of week once its in its final home in my shop.
When I run post prosper and go to mach3 the g code says 0 section 2 header not loading g code have licience when I open file says open with gcode input filter click yes no pic click no then get file pic any thoughts why
