I've noticed that when I'm (plasma) cutting smaller holes (smaller than 1/4", though I haven't found the exact cutoff size) that my hole rules will be ignored. I first noticed this when I had some irregular cuts on some control panels being cut. Checking sheetcam, I noticed that my holes were still "green" in color (full speed), vs "blue", which would signify a slower feedrate.
I made some additional cuts, and noticed on the Mach display that the feedrate was indeed at the full rate for the tool, and not the lower 60% rate dictated by the hole size. Here is a photo of my existing "holes" rules:
I'm curious about the cause of this. I've taken to putting all my smaller holes on a separate layer, and manually reducing the feedrate for that layer, as well as manually disabling the THC for that layer. It'd be nice to know what I'm doing that's disabling the cut rule execution on the smaller holes.
Thanks!
Minimum hole size for rules to be executed?
- Hole rules.JPG (49.69 KiB) Viewed 2098 times
