Hi all I have built a cnc plasma with a minithc from ebay floating z axis and
have been using the mp1000thc post is there a better one I should be using
thanks any input would be cool
post processor help
Toes,
You have a few things at work here....
1) it sounds like you have the THC up/down checkbox enabled even when not in THC mode on the mach3 >>>ports and pins>>mill options tab
2) it also sounds like you do not have a very long delay set on the THC... Hence increase the delay.
3) I presume that is the po-mo mini THC, that being the case it has a THC inhibit input....need to check the manual... I'll be back later
Rob
Rob
