TNG development V6.1.15 released
Les Newell les.newell@...
Post by Les Newell les.newell@... »
Hi all, I have just uploaded V6.1.15 to www.sheetcam.com. This release
has the following changes:
Fixed: Rotary plasma outputting inaccurate coordinates on rectangular
tube with a very small corner radius.
Fixed: Rotary plasma simulation not limiting feeds to the rapid feed rate
Fixed: Rotary plasma options always defaulting to 'flat sheet'
Changed: Rotary plasma now limits corner radius to a minimum of 0.1mm
Added: arcResolution setting to RotaryPlasma posts. This controls how
smooth arcs are when cutting pipe or around corners
Fixed: Importing splines with sharp corners sometimes results in
chamfered corners
Fixed: Debugger not showing the current line when debugging Lua scripts
or posts
Fixed: Material name not being saved with the job
Fixed: Path rules not always using the correct feed if two rules have
the same start or end point
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
SeanP
Corel File
Post by SeanP »
That's great getting the corner chamfering problem sorted.
Just tried a quick file from Corel R11 dxf and so far looks good, but other dxf formats from corel seem to freeze and lock up sheetcam on mine, TNG loads them fine though.
R11 dxf.dxf
(9.71 KiB) Downloaded 357 times
R14corel dxf.dxf
(45.22 KiB) Downloaded 362 times
Vmax549
Post by Vmax549 »
HIYA Les, I do not see that the Material Name is working. It is not being saved. Also the debug still does not set the bookmark.
(;-) TP
