PLATE MARKING Question
Jose Maria Garcia
Post by Jose Maria Garcia »
Hi there guys,
What would be the best way to mark on a plate, the center of (250)
1/4"(7mm)diameter holes, to be hand drilled later? Could you give me a step
by step help?
Jose
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
Hi Jose,
I assume you are using a plasma cutter. Do you have a plate marker or do
you want to mark the holes with your plasma?
In SheetCam create a drilling operation. Select your tool and the layer
with the holes on and set the min and max hole sizes. only circles
between these two sizes will be marked.
If it appears to work on simulation but doesn't work when you post
process it could be that your post doesn't support this. It is
relatively easy to fix this.
On 01/05/2014 15:43, Jose Maria Garcia wrote:
Hi there guys,
by step help?
Jose
Yahoo Groups Links
Jose Maria Garcia
Thank you for your fast response, and Yes, I am using a plasma cutter.
I followed a youtube video that directs you to put poits instead of holes for marking, is this correct? and yes it looks like it works on the simulation and not when post.
Regards,
Jose
From: sheetcam@yahoogroups.com [mailto:sheetcam@yahoogroups.com] On Behalf Of Les Newell
Sent: Thursday, May 01, 2014 11:57 AM
To: sheetcam@yahoogroups.com
Subject: Re: [sheetcam] PLATE MARKING Question
Hi Jose,
Hi there guys,
by step help?
Jose
__._,_.___
Visit Your Group
__,_._,___
Jose Maria Garcia
As always, right on the money.
Thanks so much!!!!
Jose
Sent: Thursday, May 01, 2014 12:32 PM
Subject: Re: [sheetcam] PLATE MARKING Question [1 Attachment]
You can use points if you prefer but the problem is in the post. I have attached a fixed post that should work.
Save the file to any convenient folder on your computer then run SheetCam and go to Options->machine->post processor. Click on the 'import post' button. Using teh box that appears, navigate to the post and open it.
Regards,
Jose
__._,_.___
Visit Your Group
__,_._,___
