Won\'t generate tool paths for tool #7
Les Newell wrote:
Hi Steve,
Are you trying to drill with tool 7? If so, the problem is almost undoubtedly the min hole size and/or max hole size in the drilling operation. It will only drill circles that are between those two sizes.
Yes, I was tool 7 is a drill. I checked the hole sizes and they were OK. Here’s where the problem was. A 3D PDF of the part is attached. I created the original pattern in SolidWorks DWG Editor. This mornng I went back and created a solid model, then created a drawing from which I created a DXF. This one worked so there must be something wrong with the sketch I made in DWG Editor. I’ll try to figure it out and post the problem.
http://www.forum.sheetcam.com//files/midas_2_295.jpg
