Warning: feed rate is zero
I have used Sheetcam for over 12 months with no problems, from this afternoon when I loaded various parts and run Simulation, all I get is (Warning: feed rate is zero) I have tried re-loading Sheetcam, checked my options etc., nothing seems to work.
Regards.
A number of SheetCam licenses have been copied and no longer work. This sounds like what has happened to you. If you send me your license ID (Look in Help->about) in a PM I’ll check it for you.
Hi Les
This is the same problem that i have.
I sent my licence number late this afternoon using the SheetCam “Create a Support File” option.
I will send it again via PM
Hope we can get this sorted out asap
Regards
Dunk
