tool paths arent generating correctly
sheetcam is not generating the tool paths correctly for my langmuir table When i run the post processor and start the cut all that happens are the initial piercings and the tool path isnt ran. couldn’t find any info on the problem, can someone take a look at the file and see if anything stands out?
thanks,
ryan’s trefoil.tap (575 KB)
I had a quick look at the code and cannot see anything obviously wrong. Does the Langmuir controller have an option to pre-pierce your parts? If so it could be that you have that turned on.
