TNG development V6.1.11 released
Hi all,
I have just uploaded V6.1.11 to www.sheetcam.com. This release has the
following changes:
Added: function post.SetEncoding to force g-code encoding
Added: I-beam support for rotary plasma
Changed: Measure now tries even harder to make sure the numbers are visible
Fixed: Hint icons for plugins such as RotaryPlasma stop working after
you load a job file.
Fixed: Occasional crash when deleting an operation
Fixed: Check box in face operation not enabling/disabling layer and
coordinate boxes.
Fixed: Tab mode remains disabled if you select a drilling/tapping
operation then delete it
Fixed: Simulation not displaying all languages correctly
Fixed: Variable type in variable definitions not translating correctly
Fixed: Tabs not cutting correctly if they are under a start point and
‘cleanup exit ramp’ is turned off
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
