tabs and finish passes?
I often cut thin sheet aluminum on my machine. I always use tabs when I cut out parts to keep them together and to keep small parts from being sucked up in the vacuum system. In using tabs, I will almost always edit there position so that I can easily clean up the finished part. Here is the question; If I use the “finish allowance” in Sheetcam and come back with a full depth cut and take say .010 away from the part how will I ever re-align the tabs?
Scott Sutton
In your second operation, in tabs mode right click and select ‘copy tabs from’. As long as you are using the same layer for both operations this will work.
Note this is a relatively new addition so if you can’t find it, install the latest version.
Super! Thanks!
