Simualtion of code snippets, Subroutines
Hello,
we will get an old CNC from Heckler and Koch.
This CNC has only 32k RAM and i think i must use Subroutines for our larger projects.
Im trying SheetCam TNG Development version 3.1.12 as demo.
I find SheetCam very usefull and have folowing questions:
Can you give an example of a Code Snippet wich i can run in the Simulation of SheetCam ?
Is it possible to create G-code Subroutines and simulate them inside SheetCam ?
Bernd
Simulation does not understand G-code. The problem is that every machine uses a slightly different style of g-code. Simulation would have to have a reverse post to match each machine. Instead the simulation uses a special hidden post processor that generates code that it then runs. This code is nothing like g-code.
Hello Les,
thanks for your answer.
Is there a way for me, to convert G-Code into the code wich the simulator from SheetCam understand,
and send it then to the simulator ?
Bernd
Have a look at c:\program files\sheetcam TNG\plugins\sim\sims\Sim commands.txt. Also have a look at the lua files.
If you can find your Application data folder then look in the SheetCam TNG folder for a file called temp.sim. That will contain the last code the simulator ran.
Oh yes, it’s a very nice open program.
I have found at the weekend the “Sim.lua”, wich converts the tokens from “Temp.Sim”.
So i have inserted “wx.wxLogMessage’s” at the Sim.lua to see at the debug window how it works.
Now i will try to convert also G-Code at “Sim.lua”.
May be i can work with the operation codes, to insert sub calls.
Thx for your answer
Bernd
