Sheetscam crashes
This is the sequence of events
I import a new drawing
Set my material
set my took (Donek drag knife)
Generate cut path
Programe crashes
I have had the same result with 2 different drawings
This is the windows error report
Problem signature:
Problem Event Name: APPCRASH
Application Name: SheetCam TNG.exe
Application Version: 0.0.0.0
Application Timestamp: 5446589d
Fault Module Name: atioglxx.dll
Fault Module Version: 6.14.10.12198
Fault Module Timestamp: 516e130e
Exception Code: c0000005
Exception Offset: 00147779
OS Version: 6.2.9200.2.0.0.768.101
Locale ID: 2057
Additional Information 1: 27bf
Additional Information 2: 27bfc48316b108ce3051ce14a6f49e92
Additional Information 3: 0487
Additional Information 4: 0487821147bb6cc4f83887ed8a25d801
Any help would be a huge boost!
Thank you
Lisa
The crash occurred in atioglxx.dll which is part of the ATI OpenGL display driver. The most likely reason for this is s problem with your display driver. If you do a search online you may find a more up to date driver.
Thank you for the reply!
Will do a search
I wondered if it was anything to do with the sheet cam update I recently installed so I rolled back windows which did solve the problem.
That’s interesting. What version of SheetCam are you currently using? It is possible that ATI released an updated driver which caused a problem and rolling back windows went back to the previous version.
I am running version 5.0.17 now
I have not updated any windows drivers
