Sheet cam in windows 7
I am having trouble getting TNG to load and function properly in windows 7. Is there any tricks to getting it to work or is it not ready for 7 yet?
Greg
SheetCam has been tested on both the 32 bit and 64 bit versions of Windows 7 and it normally runs without any problems. What happens when you try to run SheetCam?
After I set it up I cant get the table parameters to set the table size is only about 1/10 of the screen size and when I try to zoom in and out only a portion of the file zooms in and leave the rest at the same size. Also when I try to zoom the whole work space sometimes disappears.
That sounds like a display driver issue. Try turning down your graphics acceleration. This link has a good tutorial on how to do this. It is below the XP instructions.
Turn the acceleration right down and try SheetCam. If it works, turn the acceleration up one notch at a time. If you can get newer display drivers for your machine they may well solve the problem.
