Safe z
I have forgotten what settings i used to bring my z axis up at the End of my plasma cutting. I had set it this way to clear tip ups of cut pieces when returning to 0, 0.
I now now need to disable this setting or reduce how high the z axis travels up at the end of the cut, since i am cutting a job that is high above my slats and closer to the gantry and just don’t have enough travel for my z axis to retract up. I am using uccnc with sheetcam.
Please help.
Take a look in Options->job options->parking. You probably have a Z position specified there.
Thanks Les, will check that out
