Reverse cut side question?
Might be a stupid question but anytime I want to cut something with many inside cuts the cut side is always on the wrong side of the hole. I know I can go hole by hole and reverse the cut side but when I have over 70 holes this becomes a pain. Is there a way to reverse cut side on all the holes at once?
Mark
Change the cut side. If you were using an inside offset change it to an outside offset or vice-versa.
