rapid moves don't show correct
import dxf from plasmaspider the direction arrows they are everywhere and rapid moves are not to the starts sometimes not in part
hope this makes since to some one. hard to explain
Could you send me a copy of the job file (file->save job) with the drawing loaded and cut paths set up.
here is the 2 I send any I’ve tried same thing
Your kerf width is set wrong. Kerf width is the width of the cut. Yours is set to 0.6" while I would expect something around 0.06"
works great you’re the best
thanks
