Ramp angle and feedrate?
Hi! We are milling a copper gasket with Mach3 and were wondering about the ramp angle. We initially had 20degrees and changed it to 5 degrees for a less steep ramp. When the mill ramped down we found that it speeded up the feedrate.
Is that a bug, feature or did we do something wrong?
What did you set the ramp feed to? While ramping it cuts at the ramp feed rate.
I did not :slight_smile: Where is it??
Just above the ramp angle.
Arrggghhh… But it is not visible, until you set an angle. That is what confused me. Thanks again!
