HEY ONE KUICK QUESTION I DON’T NO A HOLE LOT OF SHEET CAM, I BEEN GETTING A ERRER: MESAGE Error: Evaluation limit reached
Post processing failed. I WENT TO (HELP) : (ABOUT) THIS PRODUCT IS UNREGISTERD. IS THAT THE PROBLEM . PLACE HELP
That error means you are in evaluation mode. In this mode SheetCam limits the amount of code it will generate. If you have a license you will need to reinstall it. Alternatively I can email you an evaluation license that will remove the limit for about 30 days.
OK I TOLD THE IT MANEGER ABOUT THE LICENCE SO HE WENT AND INSTALLED THE LICENCE. WE UP AND RUNING NOW. SI WAT HAPEN IS THAT WE UPGRADE FROM 3.1.17 TO 5.1.17 AND FORE SUM RECEN HE DERENT INSTALLED THE LICENCE ALL THE WAY. TENKYOU
ONE MORE QUESTION ON THE CONTOURS, WEN I ARRY A PART WAY I CANT SEQUENCE THE INDIVIDUAL PIERCE ? I FOUN ONE WAY I CAN DO THAT AND THATS NESTING ALL MAY PARTS ON TO AOUTOCAD AND THEN I CAN SEQUENCE MAY CUTING PATTERN. IS THER A OTER WAY OF DUING.
Yu can sequence individual parts. Right lclick on the parts window and select ‘job options’. Go to the nesting tab and set the optimisation to manual. You can now drag parts up and down the list to set the order.
TENKS FOR THE INFORMATION, IT HAS HELP MI ALOT TENK YOU. IF I HAVE MORE QUESTIONS I WON’T HESITAE TO GIVE YOU A TEX. GREAT JOB…
