Problem with TNG but not with the developement version
I installed the latest version of TNG on a new machine today and all went well on the installation and license install until I went to import a DXF and the normal window appeared asking for table position and then the table display goes all black and nothing shows up.
I rebooted and reinstalled with the same results so I installed the developement version and it works fine.
To try to narrow down the problem I installed it on my home PC with the same results (TNG doesnt work and Development does).
Anyone ran into this before?
When you open the drawing in TNG stable, make sure you have the file type set to ‘dxf’. You probably have it set to a different file type at the moment.
I feel like an idiot…that worked, thanks!
