Problem when loading G-code into cnc machine
When loading the G-code generated in sheetcam into our steel tailor unit, the following happens. Any insight into what the problem could be?
It looks like a mismatch in how arc centres are specified. They can be either incremental or absolute. Your post is probably configured for incremental while your control is set for absolute or vice-versa.
What post processor are you using?
