Posts not working
As if overnight, My post processor is not working…
What I get now:
N0010 (Filename: knowlove.tap)
N0020 (Post processor: Mach3 THC with scriber.scpost)
N0030 (Date: 29/01/2020)
N0040 G21 (Units: Metric)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: knowlove)
N0080 G00 X0.0000 Y0.0000
N0090 M05 M30
What I used to get…
N0010 (Filename: drawing.tap)
N0020 (Post processor: Mach3 THC with scriber Amore.scpost)
N0030 (Date: 14/09/2019)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: drawing)
N0080 (Operation: Outside Offset, layer1, T7: .25" Mild Steel 45a 35ipm)
N0090 G00 X18.9793 Y20.5800
N0100 G31 Z -30 F600.0
N0110 G92 Z0.0
N0120 G00 Z3.2000
N0130 G92 Z0.0
N0140 G00 Z2.5000
N0150 M03
N0160 G04 P300
N0170 G01 Z2.0000 F101.6
N0180 G03 X17.0593 Y22.5000 I-1.9200 J0.0000 F568.96
N0190 I0.0000 J-7.5000 F889.0
N0200 X15.1393 Y20.5800 I0.0000 J-1.9200 F568.96
N0210 M05
N0220 G00 Z25.0000
N0230 X96.3538
N0240 G31 Z -30 F600.0
N0250 G92 Z0.0
N0260 G00 Z3.2000
N0270 G92 Z0.0
N0280 G00 Z2.5000
What happened?? Nothing else seems not to function…
From the license ID you sent me as a PM, you have a pirated license that no longer works. If this was supplied with a machine I would recommend that you contact the machine supplier to see if they are willing to replace it with a legal license.
I bought it from a guy getting a new machine. I asked if it was a legal license, still have the conversation in messenger.
I have been seeing a lot about this in the forums today, people are saying they are getting discount codes. Can I get one? I need to purchase right away… With the praise I have given this software in the forums to the people still struggling with Fusion, hell I’ve probably sold several copies! Hell, I even made a video of tracing a part, saving it, loading it into sheetcam, creating a toolpath, posting it, loading it into mach 3, and cutting, All before fusion even starts up on the computer! LOL
If you have been ripped off by a machine manufacturer I’ll usually give a discount as it’s not your fault. However if you purchased the license from some shady person on social media, I’m sorry but I don’t generally offer a discount.
I’ve posted this 50 times in different forums asking about what software to get, touting how awesome the combination of Inkscape and sheetcam are over fusion… When I bought “the license” I had no idea I was getting scammed, I don’t do pirated software… Either way, I’ll be buying it again, can’t do without it…
Thanks!
“I can import my image, trace it in inkscape, export it to sheetcam, run toolpath, post the file, save the job, and have the machine running before fusion even fires up… Did a video to prove it once… Think it took less that 3 minutes… Ah, here it is…”
https://secure.screenrec.com/LI4FWi9Acu
I just purchased, so back to work I guess :slight_smile:
Can you install both versions on the same machine? 6.0.3 and 6.1.7x? I’ve always used 6.0.3, but would like to try the other…
Yes you can. You will need to install your license in that version as well.
