Postprocessor
Hello,
I’m working through Mach3, my cutter is a Hypertherm PowerMax 45.
The question is: which should relate to a post processor. The Hypertherm PowerMax 45, or Mach3?
The problem - no PP for a Hypertherm PowerMax 45 exists. Where can I obtain one. Or can I substitute the Mach3, or the Mach3 Plasma for the PP? :confused: Or…
Jim
You need the ‘Mach3 plasma’ post processor. SheetCam doesn’t care what make plasma power source you are using.
Assumed Mach3 was the correct PP, just wanted to make sure. Didn’t figure Sheetcam would care about the torch’s brand name.
Thanks Les
