Post Processor Output Problem
It was working fine yesterday, but now when i go to run it, it creates the file, but it doesn’t have the operations. I didn’t change anything. Any ideas?
Post Processor is EasyCNC.
Thanks.
Do the operation(s) have check marks beside them?
Do you have any saved job files from before SheetCam appeared to stop working? If so, try one of them. Does simulation work?
I do have saved jobs, the same thing happens. I tried running a simulation, I get “Warning: WARNING: Feed rate is zero” I have checked the operation and the tool, both have the feed rate set.
In that case the most likely problem is your license. The file may be corrupted or missing. Try reinstalling it. If you contact me off-list with your license serial number (look in Help->about) I can send you a copy.
