Post Process Failed.
New to the program. Tutorials helpful. Went through the process and errors on post processing. Made some changes and now hitting post button indicates" evaluation limit reached post processing failed". I’ve changed file name. no change. Do I have to go back to square one with the DXF file?
Did you purchase a license or are you using the trial version? The trial version has a limit on lines of gcode it will output.
Full version I think. I’ll check with IT. I ran the post a couple of times with different errors. (something about lead in I think.) After 3 or 4 tries it now gives me “Evaluation limit reached.”
Run SheetCam and go to Help->about. It should tell you if it is licensed.
