Pocket milling start points
I have a job (attached) that involves pocket milling. Sheetcam always wants to start the cuts in the same spot no matter what I change in the cut sequence settings. Contour cutting does not have that issue, I can start my cut anywhere using the start edit button. Can you change the start point of a pocket mill operation or is there a workaround for that? Anyone feel free to chime in. Thanks for any input.
I’m afraid spiral pockets always start in the middle. You don’t really get much control over the start position.
As a workaround you can do a number of inside offsets with different finish allowances but it will take longer to cut and is a pain to set up.
Ok, I figured that you could not edit start points. No big deal on that, I was just curious. You are right about the offset work around being a pain.
