Plasma stops at every segement end when cutting
I draw a simple 12" oval in Inkscape which may contain 5 nodes when complete. When pulled up in Sheetcam, there are about 18 white dots. “Segment Ends”. When I am cutting the oval in Mach 3, the plasma stops at every white dot which refelects on my final product…How can I get rid of the segment ends, is It in Sheetcam or Mach 3??? Any help would be greatly appreciated!!!
It sounds like your machine is running in exact stop mode.
It suggest prefixing your post processor with g64 to put it in constant velocity (also chack mach3 configuration screen and it should be in constant velocity mode (centre of screen)
Rob
