path rules
Hello,
I would like to see the functions of “Path Rules” in my G-Code.
What do I have to change in sheetcam to see the information in the G-Code.
example: i have set in sheetcam “path rules” small circle … but i can not see in the g-code.
G71
G91
G40
G92X0Y0
(Part: KONSTRUKTION1)
(Operation: Radiuskorrektur innen, i, T10: 10mm Stahl)
G0X33.651Y40.565
M39
M50
G03X5.12Y-5.12I5.12F750
G03X-4.743Y1.36J8.95F750
G03X4.743Y-1.36I4.744J7.589F600
G03X0.64Y0.639J0.64F600
M38
(Operation: Radiuskorrektur außen, a, T10: 10mm Stahl)
M08
G00 Z10.0000
G0X5.709Y-42.253
M39
M50
G03X-5.119Y5.119I-5.12F750
G02X-4.988Y0.304I-0.0J41.05F750
M38
G02X9.974I4.988J40.746F1000
M39
G02X-4.986Y-0.303I-4.988J40.746F750
G03X-0.64Y-0.64J-0.64F750
M38
M08
Z10.0000
M08
Z10.0000
G0X-39.361Y1.688
M30
The check box “Show rule names in g-code” in the Path Rules window will add the rule name as a comment.
Also, if the rule imposes a feedrate change, then the shape color will change in the visualizer, the default color being cyan or light blue for this case.
